mags are more tricky to time than the distributor due to the impulse coupling. the engine will run 3/4 " either way of the timing mark. easiest way to time it now is with a timing light. time it to the mark and see what happens. right now it is advanced and should be wanting to kick back when starting. i think it was 180 degrees out the first time you time you timed it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
