Re: Busted governor spring on Super C maybe?
Posted by Jimmy Neal on March 27, 2012 at 07:03:27 from (66.168.155.151):
In Reply to: Re: Busted governor spring on Super C maybe? posted by gene bender on March 27, 2012 at 06:25:25:
I have a super c also, when I push the throttle up the engine revs up very slow, also idles down very slow, when a load is put on it the gov. will not respond.I put a new thrust bearing in the gov, the spring looked ok as far as I could tell. could someone help? thanks
