Re: Busted crank 100 farmall
Posted by El Toro on March 27, 2012 at 10:24:28 from (108.3.225.57):
In Reply to: Busted crank 100 farmall posted by GriffNC on March 27, 2012 at 07:48:22:
The crankshaft may have failed from metal fatigue. I would have the block magna-fluxed and another used crankshaft. We had a brand new crankshaft to break in a new engine. It was from a military vehicle and we were running it on a stationary dynamometer. I was on the midnight shift and the engine made a terrible noise and the scale reading on the dynamometer was vibrating bad. I shut the engine down and called the project engineer at home. He said to
standby until he arrived.
When he arrived he wanted to hear the engine noise so I stared the engine and he said to shut it down, but it took awhile since the dynamometer
kept spinning the engine. We took an oil sample and pulled the engine off the test stand after disconnecting all the instrumentation. Dropped the oil pan and found the crankshaft had broken in the counterweight. The dayshift installed a new shaft and the second shift installed the engine on the test stand. The test continued when my shift started and we had
no more failures. Hal
