Re: Behlen Power Steering on 400
Posted by Bob M on March 27, 2012 at 11:07:53 from (65.110.154.2):
In Reply to: Behlen Power Steering on 400 posted by NE_Red_Rookie on March 27, 2012 at 10:41:01:
I spotted a Super M recently that had the Behlen P/S pump piggybacked on the factory live pump. It however required swapping the factory IHC (horizontal) distributor for a Delco (vertical) in order to clear the oil filter canister.
Suggestion: Rather than using the Behlen P/S pump you've got, you may be able to stick a flow divider on the 400 live pump outlet and supply the torque generator from that. (I have a couple Super M's with Charlynn P/S set up this way - the system works great!)
Sorry - I can't speak to the Behlen torque generator adaptation to the 400 steering shaft.
