Re: H transmission ratio
Posted by Owen Aaland on March 27, 2012 at 16:58:28 from (216.47.35.12):
In Reply to: H transmission ratio posted by ywalk on March 27, 2012 at 10:12:11:
Tractor Supply Company used to have a high speed transmission kit but it changed 2nd gear to what third was, changed third gear to what used to be 4th gear and increased 4th gear to a speed between the old 4th and 5th gear.
It worked out OK for hauling wagons but the loss of the 2nd gear speed pretty well ruined it for any tillage work.
