Re: Finally got my H running!!! (strange but true)
Posted by Janicholson on March 27, 2012 at 21:04:30 from (96.24.99.126):
In Reply to: Re: Finally got my H running!!! (strange but true) posted by sflem849 on March 27, 2012 at 16:00:37:
That would not have changed where the timing mark is
located in relationship to the spark, it still would
need to be adjusted to the correct timing (or close)
to run, and that would be at the mark + static
timing, or at full advance running. The mag will
not turn that far in its slot (IIRC) Jim
