Re: Farmall H running issues
Posted by CNKS on March 28, 2012 at 06:08:18 from (216.144.104.128):
In Reply to: Farmall H running issues posted by Harp87 on March 27, 2012 at 19:17:29:
Very common lean mixture. If it indeed has good gas flow--from your description it sounds like you have intermitent flow--remove and disassemble the carb, soak it in true carb cleaner overnight and put a new kit in it. Also, you said you "played" with the carb adjustments, that doesn't work. The proper way is to turn the main adj (bottom of carb) in until it sputters, then out until smooth. Adjust idle speed so that it doesn't stall, adjust idle mixtur by turning in and out until smooth. Repeat main and idle adjustments until you can yank the throttle back until it accelerates smoothly. It needs to run on the lean side, not rich.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
