Re: Finally got my H running!!! (strange but true)
Posted by JRSutton on March 28, 2012 at 13:50:06 from (75.130.109.233):
In Reply to: Finally got my H running!!! (strange but true) posted by Kippster on March 26, 2012 at 18:52:23:
Just a word of caution - and it may be a non issue if you never hand crank but, I wouldn't try hand cranking it till you're sure everything's set right.
Firing a little ahead of tdc can do bad things to the bones in your arms if it kicks back.
Just because it's running ok doesn't mean it wont kick back.
