Be sure the disk is situated so that the springs in the hub are away from the flywheel. If they stick out on the Flywheel side the hub will catch the Bolts, and the distance to get it compressed will be way farther than normel. Take the clutch linkage shorter to allow assembly. Use the nuts under the fingers to hold it in compression. (be careful not to drop them into the cover when getting it together, or it will need to come apart again. Use longer bolts to pull the cover closer to the Flywheel, then reinstall the correct bolts. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
