Re: Farmall M Duals.
Posted by rustyfarmall on March 29, 2012 at 08:30:38 from (216.248.71.224):
In Reply to: Farmall M Duals. posted by Mike1972chev on March 29, 2012 at 06:47:19:
If you stop and think about how a tricycle front is configured, with the tires being closer together at the bottom than at the top, then add an extra wheel/tire combo to the existing combo, wouldn't that cause the OUTER wheel/tire to carry MOST of the weight? And cause the tractor to set higher in the front?
