Ok ya replaced the pump , did you get a new pump or were you being cheap and get a used pump?? Did you loose the sump check plug spring ??? That little spring that looks like it is from a ball point pen?? that goes behind the MCV down in the lower right hand coroner ?? Did you remove and inspect all the valves in the MCV for free movement ?? did you measure the free length of all the springs or get a spring kit and replace them ?? did you replace all GSKT's and O/Rings ?? Did you check pressures ?? Did you add and extra five gallon of Hy Tran . And the big question here do you have atleast a I T manual to read ??
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
