Re: Best Cultivating Tractor?
Posted by D7fever on March 30, 2012 at 06:55:42 from (96.236.118.168):
In Reply to: Best Cultivating Tractor? posted by JHubnuts on March 30, 2012 at 04:06:19:
140 and similar models are excellent for 1 row cultivating, need to have both front and rear cultivators. I am referring to the factory cultivators. Spent many hours cultivating with one.
If you have the fast hitch, you will have to take that off if your plants have any height, so it won't drag on the plants. Factory type rear cultivators mount so that you won't need the fast hitch with them.
Like some other reply's, there are newer type rotary cultivators that can be adapted to the tractor to make it a multiple row cultivator. Also if you can adapt the rotary cultivators you can increase your ground speed. Important to decide what cultivator you are going to use before you plant , in order to get row width right to use the tractor. Have fun
