Re: Farmall 450 PTO Planetary Gear Roller Replacement
Posted by Janicholson on March 30, 2012 at 11:34:19 from (199.17.6.82):
In Reply to: Farmall 450 PTO Planetary Gear Roller Replacement posted by Hugh McKinney on March 30, 2012 at 11:03:14:
The hardness of the exosting holes is beyond machining, It would require precision grinding. Your proposition would work if a caged bearing was used. Here is a supplier of loose needles. Jim
