You could put 1000# of weight on a wheel and not break an axle. The tire would be loaded and require extra pressure to support it, but the weight is not on the axle. The differential issues with both 460 and 560 tractors were the result of using H and M designs on 6 cylinder tractors. It was wrong. Later improvements and recalls programs were used to fix them. Hanging a mounted harvester (many different types0 also created issues for F-20 H- SH- and M -560 tractors. This included axle breakage and premature bearing failure. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
