Re: The only dirt I will plow this year
Posted by Wardner on March 30, 2012 at 19:27:35 from (4.154.251.98):
In Reply to: Re: The only dirt I will plow this year posted by Dave eklund on March 30, 2012 at 17:36:18:
Those fenders are the equivalent in weight to a pair of wheel weights. Damn heavy. I do miss not seeing the tires to get a better sense of tire slippage. But when the tractor is in four wheel drive I can look at the front tires.
The other day I had a tire sidewall leakage. There was a small cut on the inside wall. Didn't know it until the tire was nearly flat. Had to fix it away from the barn to save the tube. The tire was probably junk or unrepairable before but there was no doubt about its poor condition when I got off the tractor. There was a long tear on the outside sidewall due to running nearly flat. Luckily I bought a pair of used tires at the Chapter 18 flea market last year.
Don't have a good picture of the custom tool box. It is trapezoidal in shape in order to clear the 560 Fast Hitch rockshaft arms.
