Re: Many questions about my new M
Posted by Bob M on March 31, 2012 at 05:40:45 from (65.110.154.2):
In Reply to: Re: Many questions about my new M posted by Zachary Hoyt on March 31, 2012 at 05:17:25:
- The tie rod is supposed to be straight. (It's very unusual to find one that's NOT been bent a few times!).
- The seat is was a factory option after serial #9287. I believe yours was made by Monroe from the factory as Zach mentions.
- If you want to pull the tractor to move it a short distance (a few miles), and it rolls freely with the transmission in neutral, that's OK. But DO NOT try tow it to try to loosen the engine - you risk breaking expensive parts inside the the engine. There are many better (safer) methods to loosen up an engine.
