Re: Many questions about my new M
Posted by El Toro on March 31, 2012 at 07:27:50 from (108.3.225.57):
In Reply to: Many questions about my new M posted by kennell on March 31, 2012 at 05:06:36:
Do not pull it as you may damage something in the drive train. If the engine has been stuck for a long time you probably need to tear the engine down. Pull the head, drain the oil pan and see how much water in there then remove the oil pan. If ATF won't free the engine you can try pouring some diesel fuel on top of one piston and set it on fire. Make sure the tractor is away from any building and anything flammable is removed from the tractor near the engine. Do one cylinder at a time and have the rod cap off the connnecting rod that's connected to the piston you're heating. Then use a piece of 2 X 2 oak and a big hammer to try and drive out the piston by using that oak against the connecting rod. The heat should free the piston. Hal
