Re: 560 IH
Posted by redgems on March 31, 2012 at 07:36:14 from (204.14.163.20):
In Reply to: 560 IH posted by slifnom on March 31, 2012 at 06:09:09:
There should be a set collar at bottom of upper steering housing on shaft.Also if play in shaft there are bushings in that steering housing that can be replaced.Next check bearing/bushing near starter make sure bushing and washer is good and check to see that where two ends of shafts connect,That they are tight.Just a thought make sure nut on steering wheel is tight and wheel splines are not damaged. Good Luck, Tony
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
