Re: Super A Magneto Screwup
Posted by gene bender on March 31, 2012 at 15:55:29 from (207.177.56.105):
In Reply to: Super A Magneto Screwup posted by ccaissie on March 31, 2012 at 10:20:19:
After it snaps the rotor will be in those positions. Whe the rotor position is at #1 fire does it line up with the tower wire going to #1 if not the gears turning the rotor mite be off a tooth but you say it starts good so it must be in time but your observing the position of the rotor after it fires is correct. Mite want to remove the cap after making a mark on the body where #1 tower is so when you remove the cap and turn engine over you will see the rotor should stop at that position. You must be awful close or it wouldnt start easy.
