Re: Follow Up on Magneto Help
Posted by gene bender on March 31, 2012 at 19:25:50 from (207.177.56.105):
In Reply to: Follow Up on Magneto Help posted by Phil Eastman on March 31, 2012 at 16:24:04:
You have to pull the radiator then the whole steering sector then you can remove the pulley with a puller then you can take the cover off and replace the seal. You will need to have some method of supporting the engine on back when the front is removed. Lots of work just to replace a seal. When you have it torn down check the crankshaft for wear where the seal goes as you mite need to add a speedy sleve so the new seal will hold.
