Re: Many questions about my new M
Posted by Centex Farmall on March 31, 2012 at 21:11:15 from (166.147.68.53):
In Reply to: Many questions about my new M posted by kennell on March 31, 2012 at 05:06:36:
What everyone else said, and.......
With the plugs out and the hood off, take a bright flashlight and shine in the spark plug holes. When the ambient light is dim you can see the cylinder walls and see if they show signs of surface rust or if one or more is worse than the others.
If the plugs don't show corrosion and the walls look fairly smooth it's probably just a light stick and will come loose with the PB blaster.
I have a 2 foot crescent that I can open up and get a bite on the crank pins on the end of the crankshaft. That's another way to put some pressure on things.
If the crank moves slightly back and forth, taking up bearing play, then that's a good sign.
Most definatly drop the oil pan!
