Re: 966 torsion bar leak
Posted by dkattau on April 01, 2012 at 04:29:09 from (72.100.25.13):
In Reply to: 966 torsion bar leak posted by Arnold Layne on March 31, 2012 at 18:34:55:
If you want to replace the rh oring too, you'll have to pull the pto. The load sensing arm is attached to the middle of the torsion tube, it has to come off to get the torsion tube/bar out the rh side. Best way to do this is to pull the pto. The right side of the torsion tube doesn't really move, so you should be ok with just replacing the lh orings.
