Re: cub update, again
Posted by Janicholson on April 01, 2012 at 09:04:46 from (96.24.99.126):
In Reply to: Re: cub update, again posted by Farmallboy15 on April 01, 2012 at 08:43:51:
BE aware that searching for a new carb right now (or an upper housing) is a good idea. Rusty Farmall sells and rebuilds carbs. He is a reliable source, and posts on here quite often. Jim
