Re: Regular Head Gasket
Posted by Nebraska Kirk on March 30, 2012 at 19:05:23 from (207.91.4.159):
In Reply to: Regular Head Gasket posted by The tractor vet on March 30, 2012 at 05:05:44:
Are you using the metal clad gasket or the cheaper style? The metal clad gasket has to be installed with a certain side up, while I don't think it matters which side is up on the other style.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
