Re: Farmall w/n start
Posted by Janicholson on April 01, 2012 at 15:48:15 from (96.24.99.126):
In Reply to: Farmall w/n start posted by Scott Cook on March 31, 2012 at 17:42:24:
In my opinion you do not know if it is injecting or not. Dry injector lines can take several minutes to fill, (way hard on the starter)
Use a pump type oil can with diesel fuel in it to pump diesel into the lines. Take one at a time off of the injector, and loosen the fitting at the pump. Squirt diesel into the line until filled and leaking out the pump end. Tighten the pump fitting and squire a bit more into the line and injector. Fasten the injector fitting. Repeat for all lines.
I cannot give pull starting directions as I do not know what tractor it is. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
