Re: Farmall H Water Pump
Posted by pete 23 on April 01, 2012 at 17:40:29 from (74.32.231.176):
In Reply to: Farmall H Water Pump posted by SadFarmall on March 31, 2012 at 14:44:00:
Right on with the pin. It is sometimes hard to
locate as it is in the rim of the pulley. You have
to press the rear flange off after getting the pin
out, and then of course press it back on to same
dimension as before. You can just drill a new hole
if you don't feel confident in getting pin back in
same hole.
