Posted by pete 23 on April 01, 2012 at 17:45:02 from (74.32.231.176):
In Reply to: Re: duals on a 1086 posted by j5 on April 01, 2012 at 17:18:31:
It will work fine. As I indicated that is the way some guys do it around here. Kind of expensive unless you have the spare parts wheels like you apparently have.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
