Re: '52 Super A won't start
Posted by Brian2 on April 01, 2012 at 18:33:20 from (74.14.16.161):
In Reply to: '52 Super A won't start posted by Warspite on April 01, 2012 at 18:21:40:
Check to see if you have spark.
Do you have a coil or mag ?
Does it fire at all ?
Wouldn't be a bad idea to pull off the valve cover to make sure all the valves are unstuck before you bend rods, pour oil on them too. Don't be cranking an engine that has sat for a long period of time for long since the bearings won't have much oil, if any in them.
If you have spark, the next step is the carb, is it getting fuel? there is a screen in there, as well as in the shut off bowl. You can take the fuel line off the carb to see if there is flow or not.
You didn't mention doing anything to the carb, I would take it all apart and clean it if you haven't already.
