Posted by pete 23 on April 01, 2012 at 18:40:25 from (74.32.231.176):
In Reply to: 756 D Tach drive posted by flhr62 on April 01, 2012 at 13:05:11:
Only easy fix I can think of is if the drive end is worn off. It drives from a slot in the center of the cam shaft gear and you turn the adaptor housing in as far as it will go gently, then back it out to align with the tach cable. If that end is worn off you could probably build it up or maybe just try readjusting the depth it is screwed in. Other wise,reduction gears stripped out. Usually, the problem is that the gear actually turns but it won't turn the cable as the end of cable is worn out and the square drive inside stem is also worn. I have pinched a few together over the years, not necessarily on that model.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
