Re: '52 Super A won't start
Posted by El Toro on April 01, 2012 at 19:21:15 from (108.3.225.57):
In Reply to: '52 Super A won't start posted by Warspite on April 01, 2012 at 18:21:40:
If you have a distributor you need to see if there's voltage to your coil. With the points open and your ignition switch in the on position
you should have voltage on both small terminals
on your coil. You need to use a volt meter or test lite. If there's no voltage you need to check for voltage at your ignition switch. There should be a wire feeding battery voltage to it. If there's voltage feeding the switch find the wire on your ignition switch that feeds voltage to the coil. With the switch on see if there's voltage on that terminal. If there's voltage there replace the wire from the switch to your coil. If there no voltage on that terminal replace the switch. Hal
