Re: 460 utility oil levels
Posted by rustred on April 01, 2012 at 20:41:36 from (74.200.18.156):
In Reply to: 460 utility oil levels posted by ldb on April 01, 2012 at 19:57:29:
oil fill plug is by gear shift. it takes a 3/4" drive extension to fit the plug. i have even used a square headed bolt and pipe wrench to loosen it also. the check plug is on the left under the clutch pedal platform. it takes a 1/2" drive extension fot that plug.
hy-tran oil for trans and diff., all one unit.
