Re: Char-Lynn mounted on steering post
Posted by IaGary on April 02, 2012 at 05:43:28 from (108.160.229.48):
In Reply to: Char-Lynn mounted on steering post posted by mkirsch on April 02, 2012 at 05:33:11:
I have a MTA with the Charlynn set up.
Mine is mounted under the hood above the engine on the steering shaft.
And yes I have seen several done like yours also.
I have seen them on other brands of tractors as well.
Gary
