Posted by John T on April 02, 2012 at 08:02:46 from (66.87.0.202):
In Reply to: M charging posted by Ellis Kinney on April 02, 2012 at 07:28:02:
If you dead ground the Gennys FLD post and she charges then but NOT otherwise, that tells you the gennys is okay so the problems EITHER the Voltage Regulator is bad,,,,,,,or the VR isnt well grounded (or not wired correct),,,,,,Or if its the older cutout relay system that uses the LHBD Light Switch, the switch isnt grounded or its bad or the wires bad from FLD on genny up to the switch.
The genny posts are labeled ARM and FLD, its the FLD (sometimes the smaller of the 2 posts) you ground in the above instructions
For more including the Motor test see my Troubleshooting Proceudre
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
