Posted by old on April 02, 2012 at 15:36:26 from (209.86.226.19):
In Reply to: farmal h posted by paul vroman on April 02, 2012 at 15:31:52:
Exhaust open or covered??? If it was covered pull the plugs out and make 100% sure you have no water in the cylinders. If they are dry then fill them with ATF and let it sit a couple weeks. Then set a 12 volt battery in and use short fast taps on the starter button with the plugs out and see if it spins over. Always put the plugs back in to keep dirt etc out. If the cylinder have any water in them forget the ATF your going to need to open the engine up to free it up
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
