F 20 rocker arm shafts
Posted by SDE on April 02, 2012 at 17:32:49 from (174.124.37.184):
Installed them tonight. There is a collar on the outboard end of each shaft. Is the inside end of the shafts supposed to have something on it to keep them in place also?
Should the spacers that go on the studs, but under the valve cover, be over or under the nuts that hold the rocker arm shafts down?
Thank you
Steve
