Re: Best Cultivating Tractor?
Posted by Jim Becker on April 02, 2012 at 21:09:06 from (71.252.156.130):
In Reply to: Best Cultivating Tractor? posted by JHubnuts on March 30, 2012 at 04:06:19:
That narrows things down considerably. Definitely 1 row at a time. Go with a Super A/140 series tractor. A Cub is plenty of tractor for that size, even if you expand several times over. However, wheel track on a Cub is limited to 56" while the Super A series can go to 68. You will be able to center the Super A tracks between wider rows. You might even want a high clearance version. However, the correct implements for them are much harder to find than the others, so stick with the regular versions.
The C or Super C tractors could be used but you would need a wide front end. Unfortunately, the C wide fronts have been bid up so high by collectors that it will wipe out any price advantage a C would have had over a 140. Another problem, you would have to make up your own tooling to do one row with a C.
