Posted by TJV on April 03, 2012 at 19:39:13 from (67.230.241.17):
In Reply to: 656 front axle posted by TimWafer on April 03, 2012 at 16:23:43:
A friend of mine said the hyd. jack method usually works for him with a jack on top and bottom and then rap on the tube with a hammer to break the rust loose. Or you could tie one side to a big tree and try pulling on the other side with another tractor but either way with tension then try heat and banging something should give.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
