Re: alt conversion
Posted by Bob M on April 04, 2012 at 06:17:07 from (67.240.171.120):
In Reply to: alt conversion posted by notjustair on April 04, 2012 at 05:47:48:
The OEM 6 volt generator pulley will not work on the alternator. However if the 12V generator you've got is a Delco and it has a cooling fan, the pulley/fan assembly SHOULD fit the 10 SI alternator.
Otherwise visit a junkyard or starter shop and get use pulley/fan. A pulley from most any Delco 12 volt car generator or alternator from the mid-50's thru mid-80's will fit.
Tip: Get the SMALLEST pulley you can find! The generator drive pulley on the fan hub is relatively small, and an M fan runs pretty slow. A small pulley on the alternator spins it faster and gives better results.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
