Re: Gene Bender
Posted by gene bender on April 04, 2012 at 07:37:04 from (207.177.56.105):
In Reply to: Gene Bender posted by jdjack on April 03, 2012 at 20:41:02:
I mite have turned the surge bumper spring too high. Take the acorn nut off the bottom of the gov housing then loosen up the jam nut now you can use a screwdriver to back off that spring a few turns. Now you can start engine and check response of throttle. If you want more rpms at high setting back off the bolt at the top as this one adjusts hi rpms at wide open throttle.
