Posted by Hendrik on April 04, 2012 at 07:42:50 from (194.53.253.51):
In Reply to: 656 front axle posted by TimWafer on April 03, 2012 at 16:23:43:
I'm with Ron 1456: rotating might do the trick, supported by hammering, heating and penetration potions. With pins and bolts removed on one side, drive front wheel (side where pins/bolts are removed) carefully against a solid object; this will put some mighty torque on the extension. So, let the tractor power help you. Good luck.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
