Posted by Pete P. on April 04, 2012 at 18:08:10 from (65.189.199.106):
Hello all --
The '47 cub PTO still won't stay engaged. Renewed PTO pilot bushing, replaced shift lever & collar, checked rear PTO shaft bearing - still staked down and appears to be fully rearward. I still have nearly a half inch of distance between the PTO shaft and trans. mainshaft. I've read that the front mainshaft bearing retainer may be installed backwards or may have failed allowing shaft to move forward. I've never had the trans apart as everything (except PTO) works fine and has for 10+ years, but I'm out of ideas. I would think if the mainshaft moved then gears woudn't line up and the clutch would not have enough room to separate and none of that is the case.
How much of a pain am I in for to check / replace that mainshaft bearing? I assume I need to split the tractor.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
