Re: Cub update *running good
Posted by Janicholson on April 04, 2012 at 18:50:48 from (96.24.99.126):
In Reply to: Cub update *running good posted by Farmallboy15 on April 04, 2012 at 17:33:14:
Very good. Make sure to check the repair on the carb every day before use. Always shut off fuel at the tank between uses. Jim
