Posted by Janicholson on April 04, 2012 at 19:54:03 from (96.24.99.126):
In Reply to: 130 starter posted by Beatle on April 04, 2012 at 17:23:29:
Turn on the lights. While watching the lights, start the tractor. While it is cranking, the lights should be better than 50% bright. If they dim way down, the battery could be bad (you indicate it is OK, but high amp draw can be an issue for starting. If the battery is good, the starter is drawing radical amps. Internal shorts to ground, bad bearings allowing the armature to drag on the field poles, are prime causes. If the lights stay pretty bright, the brushes could be wornout, or a bad starter switch could be causing poor contact. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
