The cable will pull the lever on the governor till it hits a positive stop, that can be adjusted by the bolt on top of the governor. With a helper present, loosen the cable clamp, and manually pull the lever till you reach the desired RPMs, adjusting the bolt stop as necessary. When the RPMs are where you want them, and the throttle lever in the full/high position, tighten down the cable clamp.
If the spring is weak, it will also not allow you to reach high RPMs.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
