Re: 656 front axle
Posted by rustyfarmall on April 04, 2012 at 05:31:38 from (216.248.71.224):
In Reply to: 656 front axle posted by TimWafer on April 03, 2012 at 16:23:43:
Hook a come-a-long to the bottom of the spindle, hook the other end to the rear axle and then put some tension on it. Douse it liberally with penetrating oil and smack the tube with a big hammer. Eventually it will come loose.
