Re: Painting an exhaust manifold
Posted by IH fan on April 04, 2012 at 09:51:55 from (108.220.170.210):
In Reply to: Painting an exhaust manifold posted by C. Amick on April 04, 2012 at 08:08:33:
I don't know how this would work on cast, but with header pipes, the trick used to be to clean real good and coat with automatic transmission fluid. Then run to heat it up and the pipes would turn gray and not rust after the fluid burns off.
Not sure how cast will react, and not sure if it will get as hot as a header on a car without pulling something pretty hard for a while. Has anyone tried this on a cast iron tractor manifold?
