Re: Sediment Bowl Improvement
Posted by Wardner on April 05, 2012 at 08:10:35 from (4.154.237.205):
In Reply to: Re: Sediment Bowl Improvement posted by Nebraska Cowman on April 05, 2012 at 03:57:43:
It was around 11% yesterday and similar today. The weatherman says it is extremely low for this area.
Not sure I will blow it out. I think the crud will probably scamper into the area behind the baffle. I'll see what I can do with a vacuum. Yep, I understand that can also cause static discharge.
