Re: 484 tachometer
Posted by jimb2 on April 05, 2012 at 13:40:00 from (174.115.9.174):
In Reply to: 484 tachometer posted by martin reece on April 05, 2012 at 04:45:39:
Hi Martin,
Is it a D-179 Diesel engine?
Most likely gear drive on the front of engine.
You can disconnect tach cable from gear drive and put an fwd/rev electric drill on tach cable and see if the tach works. Can't remember which direction to run the drill. If tach still doesn't work it could be a broken cable. If you live in a cold climate, moisture will get in the tach cable and freeze and when engine starts it will twist the squared end of the tach drive cable.
The other option is to unscrew the tach drive cable off the back of the tach and start the engine and make sure the drive cable turns. If it turns properly then problem is in the tach and will require a tach rebuild. Someone on this board mention a company to rebuilt tachs but don't remember if it was all tachs or only digital tachs.
Hope this helps
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
