After you get the old sleeves out, the new ones will go in with a little "persuasion". We used remove the piston and then wrap the new sleeves individually in newspaper. Put them in the deep freeze over night. (Make sure you # them and the piston that was in them when you remove it so you keep the pair together.) When you have the block bore cleaned & ready, oil one hole lightly, get one sleeve out of the freezer, unwrap it and slide it in the hole. (It might be a good idea to have a 4X4 or 4X6 hardwood block ready, because the sleeve might need some "friendly persuasion" from a 4-pound hammer to "get'er done", but it works.) Repeat the procedure for each hole. We did a lot of them that way when I was a kid. From about the 6th grade until I was out of HS, we farmed 800 acres with three H's and overhauled one every winter for about 5 years and never broke a sleeve. It those days you could get an overhaul kit from TSC for about $70. It included all gaskets and a sleeve & piston set along with rod bearings in standard, .010 or .020 under. As I remember it, if you needed .030 under, it was an extra $5.00. (My $0.02 worth. jal-SD)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
