Re: Mounted Planter
Posted by Jim Becker on April 05, 2012 at 20:47:16 from (71.252.156.130):
In Reply to: Mounted Planter posted by Jugum on April 05, 2012 at 17:37:12:
That is what IH called the single seed hopper. They had several different cut-off assemblies for the bottom. It looks to me like you may have a seed plate intended for a different cut-off assembly. Your cut-off requires seed plates with seed cells a bit in from the outside edge of the plate. It looks like your plate may have cells made as notches in the outer edge (used with a different cut-off assembly). From your picture, it appears that as the plate rotates, the cells don't pass directly under the cut-off.
